P 2146 Trouble Code....Jake Brake Equivalent?
Old Jan 1, 2008 | 12:23 PM
SuperTrucker's Avatar
Default P 2146 Trouble Code....Jake Brake Equivalent?
My truck keeps throwin the code P 2146. When it does it sounds like a big truck with the jake brake engaged. I am wondering since it is the first three cylinders cutting out, why cant I put it on a switch and use it as a jake brake? Or is it the same concept? It only does it when the engine is cold and you get on the throttle...??? Anybody encountered this? Thanks...
Old Jan 1, 2008 | 12:25 PM
LOGANSTANFORTH's Avatar
a jake brake shuts the valves off........sounds to me like you have an injector problem, its killing the fuel to certain cylinders.....does the engine shake violently when it does this???? cause if it dosent, it is killing the fuel to every other cylinder so it dosent get a misbalance........
Old Jan 2, 2008 | 10:51 AM
staarma's Avatar
It's more than likely your Juice doing it or a bad connection on the first injector connector.
Old Jan 2, 2008 | 03:32 PM
The code definition is:Bank one-cylinders 123 short circuit high or low. It has only done it a couple times and its just annoying because it is right when you get on the throttle and never at cruising speeds. And it happens when the engine is rather cold. I don't know. I am calling Edge to see.
robbyS
Apr 16, 2015 02:22 PM
Bighouse
Apr 9, 2015 06:51 PM
