conversion wire up?
Old Aug 2, 2011 | 06:24 AM
daytb's Avatar
Default conversion wire up?
hi got a 68 dodge putting a 93 5 spd 4x4 compleat running gear under. Getting to the point of wiring the motor. What do II bare bones need without installing the pcm and how many things can be used without the pce? Ie: fuel heater grid heater and the likes thanks
Old Aug 3, 2011 | 08:27 AM
daytb's Avatar
bump??????
Old Aug 3, 2011 | 09:28 AM
RSWORDS's Avatar
Bare bones you will need the starter stuff and the fuel cut off if you want to cut it off with the key, otherwise you can install a pull cable. With put pcm your OD won't work except on a swith and your speedo wont work, niether will your grid heaters, you can switch them too. Really not that much more to wire it up and everything will work as normal.
Old Aug 3, 2011 | 06:37 PM
crazy clem's Avatar
pcm also controls the alternator so youll need to convert to external regulator if using the 93 alternator. That looks like a cool ride, stepside or utility box?
Old Aug 3, 2011 | 10:20 PM
daytb's Avatar
yeah converting the alt its going to be a little longer than a short wide and shorter than a long wide box
Old Feb 11, 2012 | 06:23 PM
CUMMINStagetcha19's Avatar
Thank GOD for the manuel injection pumps! start it and charge it an she's running!
Torkjunky
Nov 20, 2018 08:46 PM
CGwill
Jan 26, 2015 02:10 AM
Machinist
Dec 5, 2014 01:06 AM
jdcarter
Nov 29, 2014 11:31 AM
sotomo
Nov 24, 2014 07:29 PM
