12v automatic transmission
Old Aug 1, 2011 | 08:23 PM
trentonwest29's Avatar
Default 12v automatic transmission
i have a 1994 dodge 2500 4x4 cummins diesel and it has a 47rh automatic transmission it all the forward gears work great all day long but reverse don't work anyone know what my problem is?
Old Aug 1, 2011 | 08:36 PM
turbo2332's Avatar
broke band or linkage issue? my best guess
Old Aug 2, 2011 | 03:54 PM
ok what kind of band like clutch band or shifter linkage
Old Aug 8, 2011 | 04:36 AM
turbo2332's Avatar
could be an out of wak linkage on the side of the tranny or if a band is broke in the tranny it needs taken apart.
Old Aug 9, 2011 | 06:58 PM
cumminspwr11's Avatar
drop the pan and check the rear band, make sure its adjust right and all together still, there is also a place to check the line pressure to the rear/low servo, you can also check the rear servo for leaks when you pull the vb out, use an air compressor blower nozzle on some of the line pressure holes, the rear/low servo can also flip or break in the bore
Old Aug 9, 2011 | 09:02 PM
ok thank you
InsaneDomestics
Potential Diesel Owners Forum
Jun 12, 2015 05:17 PM
02Stain
Feb 17, 2015 10:21 PM
smokee
Nov 7, 2014 07:40 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
collind82
12
Sep 30, 2014 11:23 PM
