TRANSMISSION
Old Aug 1, 2011 | 03:46 PM
trentonwest29's Avatar
Default TRANSMISSION
will a automatic transmission out of a 98 dodge 12 valve work in a 94 12 valve
Old Aug 1, 2011 | 03:55 PM
South Tx Coal Roller's Avatar
As far as I know the 94 models came with a 47rh and the 98's 47re. The rh doesn't need a computer to run but the re does. You would need to swap in the computer and add a tps to make it work right. I would use a 47rh with a lock up converter and call it good.
Old Aug 1, 2011 | 03:56 PM
1993firstgennewbie's Avatar
X2
Old Aug 1, 2011 | 04:15 PM
what does a lock up torque converter do?
Old Aug 1, 2011 | 04:49 PM
When a lock up converter is "locked" your engine and transmission are directly connected with no slippage. Less slippage means that less heat is building up in the trans and that can make it last longer. Another advantage is that it gives you better performance and increased mileage.
You can check this out too
Not endorsing ats, that's just a pretty good explanation of how a tq converter works.
Last edited by South Tx Coal Roller; Aug 1, 2011 at 04:49 PM. Reason: Automerged Doublepost
Old Aug 1, 2011 | 04:59 PM
thank you that helped alot another question is if my fuel pump is turned up does that mean the star wheels is turned or not
Old Aug 1, 2011 | 05:47 PM
You can back the star wheel out until it's loose and go from there.
Here are some more links with LOTS of good info:
Beginners Thread - Read First! - Dodge Cummins Diesel Forum
94-98 Tech Articles - Dodge Cummins Diesel Forum
Old Aug 1, 2011 | 08:16 PM
thank you
Old Aug 1, 2011 | 10:01 PM
No prob man
Old Aug 1, 2011 | 11:36 PM
HelenaTDI's Avatar
Originally Posted by South Tx Coal Roller
No prob man
So what Trans are you saving up for?
