07 f250 ac problem
Old Aug 1, 2011 | 03:31 PM
07outlaw's Avatar
Default 07 f250 ac problem
i have a 07 f250 6.0L and my ac/heater defaulted to defrost only, ive checked vaccum lines and cant come up with anything, tried replacing the blend door thing and that didnt fix it...any ideas??
Old Aug 1, 2011 | 06:07 PM
Mdub707's Avatar
They usually do that when there is a vacuum leak and you engage 4 wheel drive. Does it do it when you're selecting 4x4 on the switch, or just anytime?
Old Aug 10, 2011 | 11:40 PM
PowerstrokeTech87's Avatar
Get a hand pump and put vacuum on every line that connects to every component except for the tank itself. did you install the blend door actuator correctly? I used to screw them up all the time until i figured out how to get them in correctly.
Old Aug 12, 2011 | 03:18 PM
smokin-but-not-Broken04's Avatar
Did you find the problem because when i turn my truck on i have the same problem but after five minutes or so then it starts blowing out the vent.
Old Aug 12, 2011 | 03:24 PM
justin mccabe's Avatar
call berge ford in mesa az. and ask for richard freeman he is my uncle and he is a guru when it comes to any fords he is the master mechanic there
Old Aug 12, 2011 | 06:21 PM
bobfbigman's Avatar
The 4 wheel drive thing is the orings on the hub or the seal on back is shot, most times I think it is the Oring though, my hub **** had a hole in it but a little silicone cured my problem..
Old Aug 12, 2011 | 07:47 PM
Mdub707's Avatar
I have two brand new hubs, o-rings, and wheel bearings, auto 4x4 still doesn't work. Also swapped pumps on the passenger side inner fender under the hood there, with a known working one, still doesn't work!
Old Aug 13, 2011 | 04:25 PM
bobfbigman's Avatar
don't know then, follow each line from the tank and see if any are busted.
Old Aug 13, 2011 | 05:09 PM
justanother92's Avatar
Had the same prob on 05. First off the rubber lines were rotted off the inner knuckle and thus auto 4x4 wouldnt work. Then the same vent issue, turned out the little vacum selenoid on passenger side behind battery was shot, it was stuck open and therefor wouldnt let the system build a vacum. It was like 50 bucks from ford now auto hubs work and everything is right.
Old Aug 13, 2011 | 05:34 PM
Mdub707's Avatar
That's my next step, just too lazy!
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
ish1521
Aug 26, 2015 08:42 PM
txweslawyer
Nov 23, 2014 12:12 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
