New Trans, New Problem (wiring)
(back story) Transmission went out, My son pulled it for me he can not remember where everything went....
So I finally found the bracket that was lost Now I got two plugs I cant find where they go. First one is on Transmission its self on top of pan it is YELLOW and far as i can tell has to prongs...
Second Is coming off the frame rail along with other wires its red and is 2 prong as well ... I already made sure they don't go together
I think i found out what the Yellow one is KICK down here link Transmission Kickdown Solenoid | 1992 Dodge D250 3/4 ton P/U 2WD 6 Cylinders C 5.9L Turbo Diesel | AutoZone.com I can not find what plugs into it ?????
Also The red one any Ideals or web site that show wiring or anything
Thanks for the help
Thanks for the help
So did you rebuild it and put the same one in? Or is it a new one all together? I also assume its an automatic, right? I have a manual and the only wire i have to hook up is the reverse sensor so my reverse lights come on in reverse. It could be a speed sensor, but i honestly dont know a whole lot about automatics.
mine is a w 250 there are four hook ups on my trans, a three prong that goes in horizontaly a two prong that goes in vertically on the top rear of the pan area, there is also a two prong that attaches to the temp sensor in the trans line, and on the tail shaft area there is a two prong that hooks up to the vss. all these come from a harness that runs down the top of the trans. the only ones that i have colors for are the temp sensor green with red tracer and blue with blk tracer. i dont know how the 2wd harness differs from 4wd hope this helps
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
dc2188
Sep 5, 2015 10:41 AM
