ve to p7100
Old Jul 31, 2011 | 06:13 PM
lauber_03's Avatar
Default ve to p7100
got a 92 12 valve and dropping it into 98 chevy. hows the process from the ve to a p7100 if anyone knows?
Old Jul 31, 2011 | 09:11 PM
cummin_un_glued's Avatar
FormerVendor
timing case, pump gear, pump, injector lines, injector pop pressure change, throttle linkage....if auto trans, TPS, kick down cable
Old Aug 1, 2011 | 05:26 AM
lauber_03's Avatar
ok thanks
Old Aug 3, 2011 | 12:49 AM
spoolin12v's Avatar
hi im new to the board and diesel world. does any place sell everything u need as a package deal to do a p-pump conversion?
Old Aug 3, 2011 | 01:18 AM
geddy's uncle's Avatar
Unforch, I think the answer to that question is "salvage yard" if you can find an unmolested donor truck or "e-bay" if you have to resort to piecing it together
Old Aug 3, 2011 | 10:52 AM
Thekingrulz69's Avatar
Anyone have a rough price estimate to do the conversion?
Old Aug 3, 2011 | 11:54 PM
FormerVendor
since non of the kits are complete with every little part that you will need figure $2000 for vp44 to p7100 plus the pump since pump options make the price of it change too much to list
ve to p7100 you get to save the price of the conversion lines (350-600) depending on whos lines and clamp options
Old Aug 5, 2011 | 09:40 AM
centexhogdogger's Avatar
I spent 1200 for all parts and installed..
Were u located I can hook u up
Old Aug 6, 2011 | 08:43 AM
forgasm's Avatar
i had 2200 into a rotary to p pump conversion, worth every penny
Old Aug 6, 2011 | 08:48 AM
NadirPoint's Avatar
Default No Doubt
Originally Posted by geddy's uncle
...the answer to that question is "salvage yard" if you can find an unmolested donor truck
I'd be looking for a 2nd Gen long block. Much easier, quicker, cheaper and better chance of success than doing a conversion.
