ac quit blowing outta vents ... is this a vacumn line problem
Old Jul 31, 2011 | 01:17 PM
IfItsNotSmokingItsBroken's Avatar
Default ac quit blowing outta vents ... is this a vacumn line problem
I have a 94 dodge and my Ac just stopped blowing out my vents but comes out defrosters is this just a vacumn line problem or bigger
Old Jul 31, 2011 | 02:08 PM
Cummins97's Avatar
Good chance it's vacuum line. Also could be a bad actuator under the dash that moves the blend doors that went bad.
Old Jul 31, 2011 | 02:33 PM
Any idea witch vacumn line it might be
Old Jul 31, 2011 | 02:49 PM
BACONBITSFORU's Avatar
Mine did this a while back and it was a broken vac line a good way to test it is to see if your cruise control still works or the 4X4 both are controlled by vac
Old Jul 31, 2011 | 02:56 PM
So my 4x4 is ran buy a vacumn accuater or not cause my front axel has one but its welded in the locked posistion on the axel ..... And them vacumn lines are just tucked under the truck..... I think I have a problem
Old Jul 31, 2011 | 04:57 PM
RAW's Avatar
RAW
I would say so, thats not doing your front diff and t-case any favors. Vac pump is below the injection pump, and the lines come up to the fire wall above the injector fuel lines. Check in that area.
Old Aug 1, 2011 | 12:13 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Check out the vacuum line diagram at the bottom... That might help you. I book marked this page cuz i always hear this question
Central Axle Disconnect (CAD) System Troubleshooting
burndiesel
10
Feb 7, 2023 01:15 AM
