trans preheater ?
Old Jul 31, 2011 | 10:34 AM
crazy clem's Avatar
Default trans preheater ?
I havent got a FSM yet so what is the tank on the pass side of motor with coolant and trans lines coming out . is it critical or can you ditch it when it rots out? Ive had lots of dodge gassers w 727s and have never seen somethig like this.
Old Jul 31, 2011 | 10:47 AM
geddy's uncle's Avatar
It's a heat exchanger. Don't know if it's intended for tranny warming in cold weather so much as cooling, though. I only dealt with it one time, way-back-when, when the hose ruptured, and I left a several-block-long trail of ATF behind.
Old Jul 31, 2011 | 11:04 AM
tower_ofpower's Avatar
I believe it's dual purpose, durring winter while movin the ATF will heat up faster than the coolant so it aids in coolant warm up for in cab heat. But while pulling heavy loads it increases the cooling capacity of the transmission as it uses the whole engine cooling system. Not critical tho.
Old Jul 31, 2011 | 08:32 PM
backwoodsW250's Avatar
Dodge discontinued it. When I had problems with mine the dealership told me to just install an aftermarket cooler and scrap the whole shebang. To reroute the coolant line is easy as pie just need 8-10 in length of 5/8 hose. Hope this helps
Old Jul 31, 2011 | 11:59 PM
crazy clem's Avatar
thanx for the info guys
Old Aug 1, 2011 | 03:30 AM
sweetv8s10's Avatar
Could u post some pics?
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
Walker.B
LB7 Performance
Jun 29, 2015 09:38 PM
kydieseltech
May 28, 2015 05:00 AM
Pyrohigh
Oct 11, 2014 07:59 AM
