1984 z28 built 355
Old Jul 29, 2011 | 10:26 PM
blazier18's Avatar
Default 1984 z28 built 355
305 high out put spun a bearing was replaced by a 350 block bored .30 over 4 bolt main 2 piece rear main .10 block high nickel content sealed pro bearings 10/10 crankshaft forged rods trw flat top pistons 488 lift cam 110 lobe 416 heads with fresh valve job new valves and z28 springs good to .550 ;lift edlebrock 600 carb high performance distributor with 65k volt coil 7500 rpm module heat wrapped flowtech shorty headers stock transmission stock rearend new ceramic brake pads and sway bar end links black gta wheels with khumo tires half tread left. interior is in decent shape needs panels put back on where i pulled headliner. put new 6x9 speakers in and cd player. all gauges work seat has small tear blacked out headlights and tail lights. runs good cold natured everyting seems very tight. 2500$ (motor is worth that) 865 659 0466 call or text i dont know hwo to post pics. i can email pics of motor interior and car somebody needs it!
