24V no start, Semi fixed need a solution.
Old Jul 29, 2011 | 10:12 PM
Tweaker727's Avatar
Default 24V no start, Semi fixed need a solution.
So my friend has a 99 Freightliner tool truck dealio, which all the sudden died on him,
One shop put on a nice Fass lift pump ( factory one was dying i guess ? )
He winds up with a random no start, Next shop he went to, sold him a 2800$ VP pump,
and he still winds up with the no start when hot.
Then he finally calls me to help him ( i claim to know everything in the first place, so why not ? )
I run down the details with him, and tell him to unplug the lift pump, and see if it starts, calls me back and says " Yep sure does, shut the truck down, plugged it back in, and went back to a no start"
So with the help of a Innocent bystander, it took some unplugging and starting, then re plugging in the LP.
Long story short,
If the VP has allready been replaced, Do i demand that they warranty the " Reman pump from canada " and make sure i get one with the updated diaphragm ? Or is there another trick in the book ?
It's costing him 1000$'s and he wants this fixed ASAP !
Thanks
Nick
Old Jul 30, 2011 | 01:11 AM
RAW's Avatar
RAW
Does the lift pump run as soon as the key is turned on, if so, for how long? It should only run for half a second or so, just enough to push fuel into the pump, but not enough to pressurize it.
Old Jul 30, 2011 | 08:49 AM
Tweaker727's Avatar
If i'm not mistaken, it was wired to the factory setup, so i'm not sure if it's momentary prime or if it's constant.
I know my truck is setup for the momentary, or if i bump the key it'll hold for 20 seconds.
Which makes me ask, why dose my truck start just fine with 20 second hold of 20 PSI ?
Old Jul 30, 2011 | 10:57 AM
RAW's Avatar
RAW
Is the FASS wires into a relay, or directly to the lift pump connector. A FASS may pull too much amperage for the poor little controller to deliver, and change starting characteristics.
Old Aug 12, 2011 | 10:03 AM
kymaco's Avatar
Default Try this
Did this to mine and all is well.
( the second post )
https://www.dieselbombers.com/5-9l-2...lift-pump.html
Cavnar
Sep 9, 2015 07:18 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
Downd19
Dec 30, 2014 02:49 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
