Waste gate opens to soon?
Old Jul 28, 2011 | 01:59 AM
dieselpower91's Avatar
Default Waste gate opens to soon?
Im having high egt problems, new stock turbo, if the wastegate isnt adjusted right and opens to soon, coul that be why my egts get to 1400 deg.?
Old Jul 28, 2011 | 11:10 AM
94 12valve's Avatar
could if the 1400* is with very little boost
Old Jul 28, 2011 | 09:00 PM
yes, im pretty sure i was at 25psi, this turbo sucks compared to my other one i had.
but, this one seems like its opening too soon.
Old Jul 29, 2011 | 02:50 AM
BRE's Avatar
BRE
Why start two threads?
Old Jul 29, 2011 | 05:48 AM
94 12valve's Avatar
thats not what I ment by little boost ... if the gate was stuck open you couldent build boost until the top end
Old Jul 29, 2011 | 09:40 AM
oh i misunderstood, but a put a pressure/vacuum gun on the wastegate, it opens at 25psi, it actuates just fine.
how would i go about adjusting it?
Old Jul 29, 2011 | 10:53 AM
94 12valve's Avatar
through your boost elbow
Old Jul 29, 2011 | 11:16 AM
no, i wasn't sure, doesn't the boost elbow only restrict high flow pressure? i think if i put my pressure gun on it it will open at the same time? but i will give it a try.
Old Jul 29, 2011 | 11:55 AM
zjohnsonua's Avatar
I didnt see that you had two threads and had already checked the travel. Yes, the boost elbow only adjusts pressure. Your actuator rod just needs to be shortened. Start with one turn of the rod end since it won't take much adjustment to get the wastegate right.
Old Jul 29, 2011 | 01:02 PM
94 12valve's Avatar
no need to shorten the rod with a boost elbow ... all you have to do is adjust the elbow. if you know 25 psi is when the gate goes full open set the press comming from the elbow to 25 psi when you want the gate to open.
