oil filter relocation kit
Dodge 94-02 5.9L Cummins Diesel Remote Oil Filter Relocation Kit HP10006
will it work on our trucks?
Last edited by F350Fummins; Jul 27, 2011 at 11:58 PM. Reason: Automerged Doublepost
Simply put; yes. You may have to buy a different fitting as the 45 they tell you to install in the bottom will cause the hose to sit on the frame. Where you mount it is up to you, they give you plenty of hose. I mounted mine up on the front radiator support and still had 3-4 foot left over.
Thanks.
Snug plus 1/4 turn, that's about every automotive filters "specs" unless you have a gorilla grip hand tight is sketchy at best... Mines hand tight and it has a tendency to have a weeee bit collect on the bottom of the filter. Waiting for the day it lets loose. Even after only tightening by hand the dang things always come off fighting.
