gmc duramax
Old Jul 27, 2011 | 06:58 PM
reneewynn's Avatar
Default gmc duramax
2003 gmc motor and tranny gets hot under load. 30 0degrees. plety of water new filters fun runs all the time . any suggestions
Old Jul 28, 2011 | 07:01 AM
turbostang7's Avatar
wrong place for this isn't it? i asume you mean fan runs all the time? there are a few things to check first off if your fan is running non stop it has a siezed clutch and that will heat your motor up, mine did when it siezed. another thing to check is how clean the radiator, intercooler, trans cooler is. could just be very dirty and need a cleaning.
anything in front of them behind the grill, or in front for that matter?
is it possible that the water pump is bad, they are infamous for going bad on these.
Old Jul 28, 2011 | 09:35 AM
reneewynn's Avatar
Default 2003 duramax
where should this be? thanks for the reply will check all these things.
Old Jul 28, 2011 | 01:47 PM
Default Re: gmc duramax
In the duramax forum
Sent from my DROIDX
Old Sep 23, 2011 | 02:15 AM
greywarden's Avatar
this also happened to me because i am just ignoring rust building up on my radiator. it cost me lots of money just to get my gmc back on the road again. so now i do radiator flushing every 2 month sometime less because i am an everyday driver. it is the best way to protect you expensive gmc engine parts. also check for leaks in your radiator. always use the coolant from your dealer.
Old Sep 23, 2011 | 05:27 PM
BriteWhiteRam's Avatar
If you use proper GM dexcool you shouldn't hardly have to change your coolant, once every few years....
Bamafantrey
Aug 24, 2015 09:30 AM
Jun 5, 2015 01:48 AM
Jan 8, 2015 12:10 PM
gonza
Nov 17, 2014 03:51 PM
Oct 18, 2014 10:10 AM
