any suggestions on cheap power upgrades?
Old Jul 26, 2011 | 09:10 PM
camden.holper's Avatar
Default any suggestions on cheap power upgrades?
just bought a 91 ram at an auction and i need to know what some good cheap upgrades i could do in order to produce more torque and more smoke
Old Jul 26, 2011 | 09:29 PM
cummins smokin's Avatar
Carefull on the smoke topic here... you will get raged pretty hard... but the first thing you should get is gauges! THEN do the simple pump mods. Also a denny t fuel pin and a 3200 rpm spring work wonders..
Old Jul 26, 2011 | 10:12 PM
alright thank you
i'll look into it
Old Jul 27, 2011 | 01:03 AM
1989w250's Avatar
Air filter $20-$60 (just put it on the turbo I removed the old one completely), Straight pipe $20-$30 i went to NAPA and got the correct amount of 3'' pipe and some exhaust clamps and slapped it on in like 15 min. Denny, T fuel pin $105 defiantly worth it. And this is how to install and or rotate the fuel pin and turn pump up.
P.S. he also tells you how to get smoke
Old Jul 27, 2011 | 09:17 AM
98cummins's Avatar
I myself was wondering if that denny T pin and spring helped alot. My big problem is is there a way to make a little more power with out completely bombing my mileage. The best mileage I have seen lately has been 12.5. Keep in mind this is a 92 1 ton dually ex cab.
Old Jul 27, 2011 | 09:52 AM
1989w250's Avatar
Your mileage will get better with upgrades that ''Free up the engine'' AKA the less restriction of airflow and fuel you have, the more power and milage you get. How quickly can you get the air and fuel through the engine? Larger turbo, Less restrictive air filter, Bigger injectors, Bigger fuel pump, Less restrictive exhaust, Ect. Thease are all improve your engine efficiency.
Old Jul 27, 2011 | 12:38 PM
98cummins's Avatar
ok got the exhaust covered with 5 inch stacks and just the short stock down pipe but tryin to figure out the best option for the air filter. I'm a little pissed as dodge didnt give alot of air intake in that corner I removed the box and have the filter sitting in the corner right now but any of you guys have a better set up?
Old Jul 27, 2011 | 01:36 PM
1989w250's Avatar
this is how i did it. skip to 0:30
Old Jul 27, 2011 | 03:28 PM
sweetv8s10's Avatar
This is what I done.
Old Jul 27, 2011 | 03:54 PM
i just ordered an asa cold air intake from pdr diesel because i do not feel like making my own and taking the chance of sucking a boot or metal fitting through the turbo.. Also with the denny t, as long as you keep your foot out of it (its hard at first) it should not effect your mileage
