Battery go boom!...
Old Jul 25, 2011 | 04:40 PM
dalton06's Avatar
Default Battery go boom!...
Has anyone else's battery ever explode? Well mine just did. Popped the hood and top was off the battery and a mess was everywhere. Even took off some of the paint next to the top of the hood. DAMN
Old Jul 25, 2011 | 04:46 PM
BACONBITSFORU's Avatar
Need to get some basic fluid STAT to keep the Sulfuric acid from eatin away every thing under there
Old Jul 25, 2011 | 05:02 PM
dalton06's Avatar
What's basic fluid?
Old Jul 25, 2011 | 05:07 PM
Benjamin's Avatar
Bombardier
you can use baking soda, it will neutralize the acid. if you mix an acid, and a base it will neutralize each other. baking soda is cheap and effective, you can throw it on as a powder and it will stick to the acid, then mix up a baking soda and water solution to spray on and wash it all away.
do you have any pictures of the battery?
Old Jul 25, 2011 | 05:23 PM
dalton06's Avatar
Na I didn't think to get one til after too battery away. Caps was off the top and it swelled up on sided. Thanks for your help.
Old Jul 25, 2011 | 05:30 PM
rednekroper05's Avatar
Did it just pop the caps on the battery? Mine did the same thing awhile back
Old Jul 25, 2011 | 05:32 PM
dalton06's Avatar
Popped caps, expanded and sprayed everywhere.
Old Jul 25, 2011 | 05:47 PM
Yup mine did the same thing. Did you see a spike on your gauge prior to the caps blowing ?
Old Jul 25, 2011 | 06:42 PM
dalton06's Avatar
Just noticed batt volts down a bit. That only thing I noticed.
What's yalls voltage at when cranked. Lil under 14? I can't remember what's normal.
Old Jul 25, 2011 | 08:13 PM
turbostang7's Avatar
i had one explode on a piece of machinery i was working on. i was leaning over it just before it went leaned back and hit the key to see if it would crank yet and "boom" had to take a baking soda bath . not too fun. i have pics of the battery somewhere if i find them i will post them up for ya.
usually happens when the battery is about to die. the hydrogen gas builds up during charging and discharging and if the connection is a little weak it could spark and make a huge mess .
