Needing Some Knowledge
Old Jul 24, 2011 | 08:35 PM
Goose1991's Avatar
Default Needing Some Knowledge
Well my dd jumped time so now I need to fix my 1st gen within a week or so.
It is a 1991 non ic 4x4 auto. I have a list of all problems which i believe and hope they are minor.
1st. Sometimes it is very hard to start. The engine will spin and spin but never catch even in 90 degree weather.
2nd. When it does start it has a rough idle for about 10 seconds then it idles smooth as better. Any advise on the rough idle? I thought maybe timing.
3rd. When going down the road at a slow speed and hitting a bump the whole truck will start to wobble.
4th. The battery will not stay charged, it is a new battery and alternator as well. Could the voltage regulator be causing this?
5th. No radio, headlights only work on bright, and the wipers doesnt work. I can hear the motor so i think it may just be the switch.
6th. The steering is very sloppy. Is there anyway I could tighten it up for the time being.
7th. I would like to wash the engine what would i need to cover or not get very wet?
Thanks in advance guys any info ya'll can give will be very helpful!!
Old Jul 24, 2011 | 09:25 PM
cummin_un_glued's Avatar
FormerVendor
1-2 sounds like a fuel leak that is letting air into the system that would cause both of those problems, the rough idle is most likly because its not running on all of the cylinders when it first fires
3- worn out steering parts will cause "death wobble" new steering stablizer will help
4- sounds like you got that one figured out allready
5- checked all the fuses?
6- there is an adjustment on the steering box but i figure you need TREs
7- i would keep the high pressure off of the TPS and the injection pump
Old Jul 24, 2011 | 09:37 PM
Goose1991's Avatar
Would a fuel leak around the fuel filter cause this the hard start and rough idle. The previous owner said it had started leaking on him.
Old Jul 24, 2011 | 09:39 PM
FormerVendor
yes thats the most common place
Old Jul 26, 2011 | 01:05 PM
Goose1991's Avatar
How could i fix it? Could the previous owner just installed it wrong causing an improper seal?
Old Jul 26, 2011 | 06:17 PM
FormerVendor
possible, get a new filter that way you get a new oring
Old Jul 26, 2011 | 06:25 PM
dcpowell17's Avatar
Most caster (death) wobbles on straight axle trucks are caused by a bad track bar. A new stabilizer is probably need after the wobble hammered it. Ball joints are often over looked so check them as well. I just spent 10 years with 4 Wheel Parts and have seen this issue 100s of times.
Old Jul 26, 2011 | 06:32 PM
RSWORDS's Avatar
Fuel system leaking down, getting air in the system
See above
Something loose in the front end, get a friend to rock the steering wheel back and forth and follow all the arms and joints. Find the one thats loose. Might be more then one.
Yep
The plastic joints on the wiper linkage are bad/broke, I did a write up somewhere on here on how to fix them
See #3
Any air inlet/electrical
Answers in Red... Hopefully it gets you started!
EDIT: Here is the link to fix what is most likely wrong with your wipers...
https://www.dieselbombers.com/1st-ge...look-here.html
Old Jul 28, 2011 | 06:01 AM
oldfirebird's Avatar
As for the headlights, start out front. Check for voltage at the bulb. Sometimes people don't notice one bulb is blown till the second one goes. If you do not have power at the bulb, take a look at the plug on the dash switch. I had a 93 that burnt up one of the wires in the socket. My solution was to clean up the switch, yank the wire out of the socket and drill a hole through where that wire clipped in. I installed a new termination on the wire. Then passed that one wire through the drilled hole, connected it up to the switch and plugged the socket in over it. A lot cheaper than replacing the whole socket.
Old Jul 28, 2011 | 08:26 PM
DieselRamcharger90's Avatar
All the answers here seem pretty accurate.. and my voltage reg. was doing the same to me. But as far as steering issues go, I have one word for you Borgeson! Look them up, they have worked wonders for a lot of guys. The Mopar steering shafts were severely lacking strength and this new one can shore up a lot of issues! Hope that helps bud
