t case oil
Old Jul 24, 2011 | 03:06 PM
coors_man_2005's Avatar
Default t case oil
fixing to change the front seal for my drive line cause mine is leakin but what oil should i put back in i really dont want to put atf back in it thanks guys
Old Jul 25, 2011 | 04:42 PM
noone knows?
Old Jul 26, 2011 | 03:16 PM
Heath's Avatar
Authorized Amsoil Dealer
I don't claim to know much about the needs of the tcase beyond the recommended ATF, but there are lot of duramax owners that use 5/30 motor oil in theirs. I can't imagine that the components would be that different but I've not seen the same use in dodge owners. There has been good success in the dmax owners.
Just thought I would throw that out in case there are some users out there that might throw their 2 cents in.
Old Jul 26, 2011 | 05:07 PM
thanks for the response something to check into
Old Jul 26, 2011 | 05:32 PM
NadirPoint's Avatar
It needs a lighter oil like ATF because it's a chain-driven t-case.
Why don't you want to use the recommended fluid?
Old Jul 26, 2011 | 11:24 PM
i have just seen like lazar smith sells his blend of lube for the g56 called gorilla juice its good stuff but i cant afford it right now and figured there would be somthing out there to offer better protection then atf but yet flow good enough to hurt anything
Old Jul 27, 2011 | 07:46 AM
NadirPoint's Avatar
Default Riiiight....
Gorilla Juice?
Old Jul 27, 2011 | 04:27 PM
Default what
Originally Posted by NadirPoint
Gorilla Juice?
do you even know anything about it?
Old Jul 27, 2011 | 05:27 PM
NadirPoint's Avatar
Default Why Don't You Educate Me, Then....
I know enough about this vendor's products to find just about anything he sells pretty amusing. But if you think this "Gorilla Juice" is the best thing for your transfer case, why don't you go right ahead and explain exactly why.
I'm all ears....
Old Jul 27, 2011 | 05:57 PM
wildbill's Avatar
ATF+4 is synthetic, though not a FULL synthetic. Gorilla juice? Sounds like a $10 chip that will increase your fuel mileage by 5 mpg.
