need some help on my 6.9 idi
Old Jul 22, 2011 | 06:05 PM
logan80's Avatar
Default need some help on my 6.9 idi
I have a question on my 6.9 idi I found a set of new injectors on craigslist never been open still in the plastic and was told 6.9 and 7.3 idi used the same injectors is this true? My truck runs rough like it has a miss and sometimes when u go out and start it up for the first time it dies and u have to crank it for6to 8 seconds and then it starts and it will idle smooth and then start running rough and then idles smooth again its kinda frustrating. But I was told the truck needs injectors it has 213,000 on it and they look like they are original. Thanks for any kinda help.
Old Jul 22, 2011 | 07:44 PM
DieselCrawler's Avatar
yes they are the same. find out the code on them. stay away from g codes. also if installin injectors, get a return line kit and change them at same time.
Old Jul 22, 2011 | 08:02 PM
logan80's Avatar
Are the codes stamped on the injectors? And what are some of good ways to test the injectors because I really don't want to buy injectors if it doesn't need them?
Old Jul 23, 2011 | 06:33 AM
only way to tset the injectors is to send them out to a shop and have them pop tested.
codes are stamped on them yes. one of the flats where your wrench goes to remove them has it.
Old Jul 23, 2011 | 07:31 AM
logan80's Avatar
You think it would be just worth it to just put a set of new injectors in it. The truck has 213, 000 miles and I heard they are were good for around180,000
You think it would be just worth it and replace them the truck has 213,000 and I heard they good for around180,000 .plus the ones I found are $100.00 for 8 and are delphi brand not opened
Old Jul 23, 2011 | 02:26 PM
go for it then. the stock ones are normally only good for 100000 miles.
Old Jul 24, 2011 | 04:40 PM
stackboy6.9's Avatar
how good are the pensacola injectors
Old Jul 24, 2011 | 05:46 PM
logan80's Avatar
Thanks for your help dieselcrawler on telling me about the. codes stamped on the injectors
. I found the problem with truckthe the guy who had the truck before me bypassed the water separater and I found a a split in one of the lines. And it was sucking in air.. Fixed the line and it runs great.
Old Jul 24, 2011 | 06:23 PM
im having the same problem but i checked all my fuel lines and they arnt leaking.my return lines need to be replaced but im sure that wont cause it to start up and die and then crank for 20 seconds.i dont wana burn up my starter.i need help cus this is my daily driver
Old Jul 24, 2011 | 07:33 PM
logan80's Avatar
Mine wasn't leaking any fuel. It was one of the lines going to the water separater it was dry cracked.
