sct code P2290??
Old Jul 21, 2011 | 08:01 PM
ATX6132's Avatar
Default sct code P2290??
injector control pressure too low? truck is low power i can put the pedal down all the way and it takes about 10 seconds to go 5 more mph
HELP!!!!!!!!!!!!???????
Old Jul 22, 2011 | 12:41 PM
Mdub707's Avatar
Bad ICP sensor more than likely. You have an 04 so it could be easy to change or a PITA. If it's a late build 04 that sensor is on top of the passenger side valve cover, if it's an early 04 it's on the back of the motor down behind the turbo.
Does the truck have issues starting? It could be a high pressure oil leak too... but I'd guess it's not based on the info given so far... Could also be an HPOP on it's way out.
You really need to get it hooked to a scanner though, you should watch Desired ICP and Actual ICP, if they're not matching up at all, HPOP is probably going...
Old Jul 22, 2011 | 06:12 PM
bismic1's Avatar
Yeah - a P2290 code requires quite a bit of troubleshooting. It can be one of a number of things. IPR duty cycle is also an important parameter to watch. Ultimately it may require an air pressure test of the high pressure oil system (begin w/ the valve covers off).
Old Jul 22, 2011 | 09:59 PM
ATX6132's Avatar
Thanks a lot TSD has a scanner I'm gonna get it read this week ill post results thanks a lot guys
Old Aug 1, 2011 | 07:36 PM
ATX6132's Avatar
Gaskets Blown and a ICP code came up, not too sure wat it was but they said they would fix it when i get my heads done? which sucks cuz its always when its $3,700 i dont have
Old Aug 1, 2011 | 08:14 PM
Mdub707's Avatar
Ouch dude... just dropped mine off Sunday for gaskets again!
If you're paying for it, get ARP's installed, and get the heads decked!!! Do it right, and make it the last time you have to do it!
Old Aug 2, 2011 | 12:32 PM
ATX6132's Avatar
Ya that's included in there head job, I do hope its the last time haha thanks a lot man goodluck on urs!
Old Aug 2, 2011 | 01:40 PM
Mdub707's Avatar
Mine's under warranty thank god! (at least I hope!) It's in powerstroketech87's hands now... I owe him lots of these -->
Old Aug 4, 2011 | 12:26 AM
ATX6132's Avatar
i hear u on the but not the warranty (ouch)
Old Apr 18, 2015 | 07:19 PM
WilliamWaldo's Avatar
Default ICP P2290
I have the same issue but if it was a blown gasket wouldn't the oil have changed color or my truck be blowing excessive or some smoke?
