rough idle
Old Jul 21, 2011 | 07:54 PM
deagle40's Avatar
Default rough idle
i have a 2002 cummins with a vp44 hot rod injector pump, a bd deisel max flow pick up pump, afe cold air intake and intake horn, edge ez, and recently added smarty s-03. the rough idle started after the vp44 hot rod pump. it smooths out with the a/c on when warmed up, and with the a/c off when cool. any help would be greatly appreciated.
Old Jul 21, 2011 | 08:15 PM
turbo20psi's Avatar
That is normal for a hot rod pump. Same goes for the Dragon fire extreme vp44 and that pump uses the .093 Connector Tubes & .093 Injection Lines.
Old Jul 21, 2011 | 08:23 PM
deagle40's Avatar
thanks. i didnt change the stock lines. shoul i have?
Should I have changed the stock lines?
Old Jul 21, 2011 | 08:28 PM
turbo20psi's Avatar
No leave the stock line's it will make it worst idle wise.
Next thing to do is to protect the vp44 do you have a fuel pressure gauge and a good lift pump ?
Last edited by turbo20psi; Jul 21, 2011 at 08:28 PM. Reason: Automerged Doublepost
Old Jul 21, 2011 | 08:50 PM
deagle40's Avatar
yeah. i have a bd max flow that is acting up, the low pressure fuel gauge varies from 5-30 psi sporadically jumping around. the replacement will be here tomorrow. hopefully that fixes it. btw they said the new pump needs to be installed motor side up and fuel side down to prevent problems.
Old Jul 21, 2011 | 08:59 PM
turbo20psi's Avatar
You need a snubber between your gauge and the vp44 the jumping around is the pulse's from the vp44. Don't let the fuel pressure drop below 10 psi at WOT.
Last edited by turbo20psi; Jul 21, 2011 at 09:01 PM. Reason: Automerged Doublepost
Old Jul 21, 2011 | 09:06 PM
deagle40's Avatar
Is that the piece that the sending unit threads into and goes through the banjo bolt?
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
