A/C Compressor coil / clutch pack removal
Old Jul 21, 2011 | 04:29 PM
Edahall's Avatar
Default A/C Compressor coil / clutch pack removal
The coil on my A/C compressor went out and I had no luck locating another coil. So I bought a rebuilt A/C compressor. I'm thinking about removing the coil from the rebuilt A/C compressor and putting it on the old compressor since it's still good. Is it correct that the freon does not need to be removed to do this job? I'm getting conflicting answers but the A/C shop did tell me that it can be done on the vehicle with it being charged.
Old Oct 19, 2011 | 04:29 AM
jwirth's Avatar
Yes it can be done on the vehicle without recovering the freon.
Old Oct 20, 2011 | 09:15 AM
Edahall's Avatar
It was much easier to just remove the compressor and do the clutch / coil changeover on the bench. Afterwards, I refilled the system with R290 using a scale to get exactly the correct amount. The A/C now runs extremely cold and will drive you out of the vehicle even when it's 100 degrees outside.
