removing shifter knob
Old Jul 20, 2011 | 01:06 AM
wyodiesel92's Avatar
Default removing shifter ****
I've been thinking about changing out my shifter **** and just wondering if its just supposed to spin off lefty? I've taken shifter ***** off on other vehicles and it came off easy and I've tried with mine and it seems like it doesn't want to turn off, and I am worried about breaking something wrenching too hard on it trying to twist it off. Sorry for a dumb question, I tried looking in my haynes and it just said remove shifter ****, not twist or pull or anything like that.
Thanks in advance
Old Jul 20, 2011 | 01:16 AM
rednekroper05's Avatar
It's been awhile but I'm thinking mine had a nut under the shift pattern
Old Jul 20, 2011 | 01:41 AM
Do you just pop off the shift pattern like a cover with qa small flat blade screw driver?
Old Jul 20, 2011 | 07:38 AM
RAW's Avatar
RAW
I believe so, a small screwdriver or an oring pick should work just fine. My Dodge service manual say nothing about how to remove it, at all!
Old Jul 20, 2011 | 08:00 AM
KillStroker's Avatar
Depending on either you want to keep the OEM one to have around and if its any thing like the X-case shift **** run a straight blade up the the narrow part slide the that cover off and its a nut w standard threads.
Old Jul 22, 2011 | 08:00 PM
thebullet83's Avatar
they say you can take that shift pattern out without wrecking it or the ****. i don't believe that. i wrecked my **** trying to figure it out.
the **** itself is a softer plastic. the shift pattern button is a rigid plastic that is about 3/8" thick. the **** has a groove in it that receives a little lip from the shift pattern. that groove is towards the bottom of the shift pattern button.
basically, remove that button, and there is a M10 nut under it. loosen that and the **** spins off easy peesy, but i will impressed if you can without damaging it, .
Old Jul 24, 2011 | 07:40 PM
Yeah I almost got it without hurtin the **** and then got carried away and messed it up, then went to take the nut off and the whole shifter turned instead. So I boogered it up with channel locks holding it to break the nut loose.
2gCummins
Jul 22, 2015 11:34 PM
Old12er
Feb 20, 2015 10:35 PM
cdpowers
Jan 23, 2015 01:42 PM
Cummins75
Dec 10, 2014 12:17 AM
jmerriman17
Nov 21, 2014 04:38 PM
