give it throttle let off it dies
Old Jul 19, 2011 | 11:39 AM
ooley's Avatar
Default give it throttle let off it dies
just had the motor rebuild it idles fine but when it mash it and let off it dies any ideas
Old Jul 19, 2011 | 11:54 AM
South Tx Coal Roller's Avatar
What's your idle speed set at?
Old Jul 19, 2011 | 12:21 PM
ooley's Avatar
600 in gear with ac on
Old Jul 19, 2011 | 12:25 PM
geddy's uncle's Avatar
Originally Posted by ooley
800
There's yer problem... Needs to be @ about 800 in Drive w/ ac compressor engaged... Maybe even 850-900 if you're using the not-super-accurate dash tach. If you're using a high-dollar whoop-dee-doo shop tach, 800 should be good.
Old Jul 19, 2011 | 12:40 PM
ooley's Avatar
thanks will having the timing at 17.5 have any effect
Old Jul 19, 2011 | 02:39 PM
For that question, you gotta wait for a hot-rod diesel guy to show up. My answer was for stock timing, and I don't know back from forward about very-far advanced fuel-squirts.
Hell! He might tell you 600 should'a worked, or that 1000 is marginal.
Hope you're along soon, though.
Old Jul 21, 2011 | 01:51 PM
Lostnwalmart's Avatar
What is done to the truck?
Old Jul 21, 2011 | 02:35 PM
Dieselfunohio's Avatar
I idle at about 500 and I only have that problem when the engine is cold
Old Jul 21, 2011 | 02:40 PM
ooley's Avatar
it has a hx 40 turbo no fuel plate 50 hp injectors and i adjusted the idle and it quit unless i hold it to the floor and let off it will bog down and almost die and its setting 750 rpms in gear
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
1969olds
9
Apr 18, 2015 02:59 PM
Andyhc1
Mar 16, 2015 12:00 PM
1stgenswap
Nov 3, 2014 09:45 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
