Won't build turbo boost
Old Jul 18, 2011 | 04:55 PM
rodneydiesel2's Avatar
Default Won't build turbo boost
I've got an 04.5 Cummins 6 speed. Truck is all stock. Every so often the engine light will come on and it wont go over around 12 psi on boost, then all of a sudden it will start workin again and build around 22 psi. Its kinda erratic, sometimes I'll start it up and everything is fine, then sometimes engine light will be on and it will barely pull itself. Already changed the MAP sensor. Any ideas??
Old Jul 18, 2011 | 05:13 PM
cummin_un_glued's Avatar
FormerVendor
wastegate solinoid is probably going bad on ya, and they default to the open position which would cause the low boost
Old Jul 19, 2011 | 01:09 PM
Yeah, thats a possibility. The code that its showing now is 0236-MAP sensor voltage too high for too long. Am I still having a MAP sensor problem?
Old Oct 27, 2011 | 10:24 AM
Figured out the problem a couple months ago, just haven't been back on here. One of the little progs on the MAP sensor plug ins was bent and not making good contact. Just bent it back in a little with a pic and has been working great ever since
Old Oct 27, 2011 | 09:12 PM
FormerVendor
thanks for the update
avatardvr
18
Aug 8, 2019 12:38 AM
redveloce
Diesel Engine Conversions
38
Jan 22, 2017 03:55 PM
sak240
Oct 1, 2015 04:07 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
