New truck new to diesels need help
Old Jul 17, 2011 | 06:45 PM
chevycummins79's Avatar
Question New truck new to diesels need help
Well I have a 79 chevy 4x4 3/4 ton with the drivetrain out of a 1991 dodge 727 trans 205 t case and a dana 70 rear axle disc brakes 3.08 gears 32" tires. My first question is how much boost should there be? if a really get on it i get about 9 psi and on the highway driving its only about 1-3 psi if that. Also if its in neutral and I rev it up the boost gauge drops and then returns to zero. I plumbed the gauge into the head behind the throttle bracket is there a better spot for it? The second question is this truck will only go about 63mph and thats standing on the gas pedal is this normal I know its only a three speed trans. I would appreciate any help I can get thanks
Old Jul 17, 2011 | 08:20 PM
crazy clem's Avatar
mine when i bought it made 16 measured at the intake manifold ,after exhaust intake and upgrade to 16cm exhaust side of turbo mild pump tweaks 25lbs . cruising on the hiway at 55/60 1-2 lbs .in stock form they are meant to tow not go fast you are also hampered by lack of OD . read through the stickies they will provide all you need to know performance wise.before you start tuning get a pyrometer.
Old Jul 17, 2011 | 08:26 PM
justin mccabe's Avatar
yes for sure get a pyrometer before you do anything performance wise. you can also get a gov spring and a fuel pin and that should help a lot to.
Old Jul 17, 2011 | 09:08 PM
sweetv8s10's Avatar
My 92 hits 31 psi if I put my foot in it.
Old Aug 7, 2011 | 11:48 AM
Well turns out my throttle linkage had some serious play in it can hit 20+ psi now its a whole different truck thanks for the help
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
foxboy63
Chevy/GMC Duramax 04.5-05 LLY
Jan 11, 2015 01:38 AM
Oct 14, 2014 08:40 AM
