a/c freeze up
Old Jul 17, 2011 | 12:37 PM
txswm58's Avatar
Default a/c freeze up
my evaporator keeps freezing over,any advice? to much freon or not enuff?
Old Jul 17, 2011 | 01:19 PM
BACONBITSFORU's Avatar
Where do you love?
Old Jul 17, 2011 | 01:20 PM
*live stupid iPhone
Old Jul 17, 2011 | 01:27 PM
RAW's Avatar
RAW
I'm not too sure if these truck have a freeze switch, but if they do I would be suspect of it.
Old Jul 17, 2011 | 01:33 PM
txswm58's Avatar
texas were its over a 100 ever day
Old Jul 17, 2011 | 01:35 PM
RAW's Avatar
RAW
Can you hear the A/C compressor cycling? It shouldn't stay on all the time.
Old Jul 17, 2011 | 02:00 PM
txswm58's Avatar
no its not cylcing
Old Jul 17, 2011 | 05:06 PM
RAW's Avatar
RAW
While I'm looking this up, does the A/C compressor turn off when you select vents only?
Old Jul 17, 2011 | 05:14 PM
RAW's Avatar
RAW
Freeze–up Control A/C Low Pressure Switch Accumulator mounted
Low psi Control Opens < 22-24 psi Resets > 37-43 psi
High psi Control Opens > 450- 490 psi Resets <270 - 330 psi
mounted on discharge line, near compressor
If you have a set of gauges, this may diagnose if a high, or low pressure switch has failed closed. With the gauges attached, if the low side goes below 22-24 PSI and the compressor is still running, the low pressure switch is bad. If the high side goes over 450-490 PSI, the high pressure switch is bad.
It may also be a case of too much freon in the system. When did the symptoms start? Did anything change from when it worked well, and until now?
Old Jul 17, 2011 | 05:47 PM
txswm58's Avatar
yes it turns off,thats how i thaw it out.takes a few minutes
i change the evaporator coil in the dash the blower motor and orfice tube,been freezin up since
