coolant hot engine over heating
Old Jul 17, 2011 | 04:10 AM
speedy_race30's Avatar
Default coolant hot engine over heating
i have a 2005 duramax 6.6 temp quage will go from normal temp to 260 back and forth real fast i have replaced the temp sensor and the pig tail still does it, it will also do this right away even if the truck sits for days and you start it up cold will happen right away can be -10 seems like it will go days or weeks and will not do it then when it starts it does it for awile the truck is loosing no coolant
Old Jul 17, 2011 | 09:40 AM
BriteWhiteRam's Avatar
is the upper rad hose hard after sitting over night? if you slowly loosen the rad cap on the Degas bottle is there a large pressure build up?
You have air in your coolant system, thats why you're having the huge temperature swings
Old Jul 17, 2011 | 10:07 AM
no the upper hose is not under pressure if i squeeze it you can watch the coolant level go up and down a little bit in the tank
burndiesel
10
Feb 7, 2023 01:15 AM
dandbmcc
Mar 14, 2015 11:05 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
gmcmanis
Chevy/GMC Duramax 01-04 LB7
Nov 9, 2014 04:49 PM
