Speedo, tach, odometer quit
Old Jul 16, 2011 | 08:52 PM
WyoCumminsGirl's Avatar
Default Speedo, tach, odometer quit
So on my bf's 96 12v the odometer, speedometer and tachometer all quit. All the other gauges on the instrument panel works. About a week ago the speedo and tach started dancing around and the generator and check engine light would flash while the gauges were going crazy. What would cause just those three things to go out?
Old Jul 16, 2011 | 09:49 PM
12vcummins96's Avatar
it needs a cluster or it might be a bad ground
Old Jul 17, 2011 | 02:51 AM
97cummins's Avatar
If your truck has a speedo sensor on the rear end of the tranny,it may be whats causing the speedo issue.
Old Jul 17, 2011 | 03:32 AM
Mr. Miyagi's Avatar
sounds like either a circuit ground or an unhappy instrument cluster. Might have to check the connections on the back of it.
The rear VSS could affect the speedo n odometer but the tach n rest of cluster should still work fine......those issues kinda sound like either a connection or possibly a computer on the fritz....check connections n grounds first.
Old Jul 18, 2011 | 04:20 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I would have guessed the speed sensor too but the fact that the tach went out also sounds like the cluster needs replacing. Or by coincidence your ckp sensor, and vss went out at the same time
Jordon92
Dec 14, 2015 01:37 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
Cutlass26
Mar 22, 2015 05:46 PM
jcottonoir
Oct 7, 2014 08:04 AM
