fass fuel
Old Jul 15, 2011 | 03:46 AM
02 cummins in's Avatar
Default fass fuel
I bought a 2001 and its got the 150 series and i was wondering if you can run stock injectors with it, if not I will end up checking the size that is in it. just didn't know if you don't wanna tare into the motor to find stock injectors in it
Old Jul 15, 2011 | 06:25 AM
zeismaster's Avatar
Default fass fuel
If you have the fass 150 yea it doesn't matter if you have stock injectors. But if you have 150 injectors ya you will want to get a fuel system
Old Jul 15, 2011 | 08:16 AM
RAW's Avatar
RAW
It almost seems your looking at the fuel system backwards. More lift pump pressure/flow doesn't mean you need to deliver more fuel into the engine. In reality, when your looking to deliver more fuel, you need a higher flow rate from your transfer pump. If someone installed a FASS150 on a stock truck, they either had plans to upgrade, or it was more cost efficient then a factory replacement. That FASS150 will fuel the engine beyond the fueling capabilities of a VP44.
Old Jul 19, 2011 | 12:12 AM
Ok never really understood I just figured it might have bigger injectors my truck smokes I mean won't black out a four lane highway with no programmer or is that just the the nature of the truck?
JoeyMiR
9
Feb 3, 2018 10:05 PM
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
