Fuel Pressure ?
Old Dec 29, 2007 | 08:52 PM
01Diesel Bomb's Avatar
Default Fuel Pressure ?
I just put my new gauges in (Isspro) boost & fuel pressure it seems everyone on here said the pressure was a must on my year! So I put it in and I have looked at other post saying it should be 13psi at idle mine is at 11 1/2 to 12 is this a bad thing 1 to 1 1/2 psi lower then you guys say it should be, the only other reading I could get for now is WOT and that sits at 6 1/2 to 7 psi. My boost is another question for you guys, at idle 0 and WOT 20 psi are these good #'s? Thanks again for your help ( I know DAMN rookies)
Old Dec 29, 2007 | 09:05 PM
Uncle Bubba's Avatar
Your in good shape for a stock truck right where your at. The fuel pressure just needs to stay above around 8 psi at all times, give or take 1 or 2 psi is fine. That's the safety margin. If you can ever pull it below that it's time for a fix.
The 20 psi for Boost is a little low but nothin to worry about, when you put some basic BOMBS on it you will be hittin 30psi plus.
Hold on tight, it's a bumpy ride from here on.
Old Dec 29, 2007 | 10:27 PM
I know this is not about the pressure question but I have been wondering how much boost can I run with a stock struck befor I damage anything? I do have the BHAF swap and that is it. I thought about uping the boost a little more to get a little more out of it. Thanks again
Old Dec 29, 2007 | 10:35 PM
Wyatt Earp's Avatar
You won't get more than 25 pounds on a stock truck. Take said truck add some programmer or box to it and it will climb to a decent number. If that is all you do it will be safe to 38 pounds. You start getting in the danger zone when it sees more than 42 without head studs, gaskets and so on. That said, it is highly unlikely that a stock turbo setup would get you there anyway... Well, at least for a long period anyway.
My 2002 Cummins has big 150HP injectors, 4" exhaust, stock turbo, a FASS 150, gauges, a smarty box for smoke and an edge comp to reduce the smoke (yeah, I know sounds strange) and I rarely see boost above 34 pounds.
Old Dec 29, 2007 | 10:37 PM
Safely on stock innercooler boots, turbo and head gaskets I rarely go above 30psi. have hit 35 in the past for very short duration but I'm chicken. You can go higher but anything ove 30 is taken chances.
Old Dec 30, 2007 | 12:15 PM
OK so say I did bump it up to 28-30 psi am I going to see much of a change or is it even worth my time? And am I going to see the fuel gauge go down faster?
Old Dec 30, 2007 | 12:21 PM
DangerousDuramax's Avatar
You can go a little higher but your stock turbo runs out efficiency around 36-38 psi so anything after that is just a waste.
Old Dec 30, 2007 | 01:17 PM
Whit's Avatar
Site Mascot
yer fuel pressure should stay about the same..............this would indicate a good fuel delivery system
Old Dec 30, 2007 | 01:48 PM
Being mildly modified up to about 500hp you shouldn't see much drop in pressure. If your running 12psi at idle you will probably drop to 10psi at WOT. Once you start bombing the fueling rate (ie. injectors, modified CP3, heavy tuning) you will start seeing a significant drop in pressure which will require you to step up to a 150gph unit. Like Whit said, if your mildly modded then you shouldnt see much drop in pressure. If you do you've got issues with the fuel delivery system.
Old Dec 30, 2007 | 04:55 PM
These Dodges are unpredictable as hell on fuel drop. I had a period of time where i had almost 20psi of pressure at idle but as soon as I got on the go pedal it would go right to 0psi. That's why you have to have a guage where you can see it all the time.
