Coolant Flush
Old Jul 14, 2011 | 05:24 PM
hp325's Avatar
Default Coolant Flush
I've read alot on here about coolant flushes. So I bought a gallon of Restore and 2 qts of VC-9. My question is which do I use first or do I put both of them in at the same time? When I get that done I got a modified intake from Doug at Go Go Diesel which will get rid of the EGR system altogether. Also changing out the oil cooler and putting in the blue fuel pressure spring, and installing a CFM intake elbow. I know I got my work cut out for me. Thanks for any help
Old Jul 14, 2011 | 08:01 PM
PowerstrokeTech87's Avatar
while your at it use this to do your flushes and refills with.
RADKITPLUSA, Vacuum/Filler, Cooling System
Fills it to the proper level EVERY time. No need for burping either. I own it, one of the best damn tools i own! saves alot of time too
Old Jul 18, 2011 | 07:13 PM
hp325's Avatar
Got the flush done. How much of the fan shroud has to come off, looks like it is bolted to the intake manifold?
Old Jul 19, 2011 | 12:01 AM
Little Luke's Avatar
I didnt have to, I could reach inside and remove the two bolts. I just removed turbo, intake, and valve covers. never removed the fan shroud.
Old Jul 19, 2011 | 07:29 AM
Mdub707's Avatar
To get the intake manifold off like you will have to do to replace your stocker with the GoGo unit, just unbolt those two bolts from the shroud to the intake manifold. You shouldn't have to take any more of that shroud off.
Old Jul 19, 2011 | 08:51 AM
hp325's Avatar
Do you know what size socket I need for them. Thanks for the help
Old Sep 4, 2011 | 07:29 PM
herman07's Avatar
Probably 10mm.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
