kickdown cable/ tv cable?
Old Jul 13, 2011 | 09:10 PM
blackout's Avatar
Question kickdown cable/ tv cable?
i recently bought a 91 w250 with a the 727 automatic transmission. and im just wondering if it has a kickdown cable or tv cable? whatever it is ,its unhooked and ive been looking around and it says the tv cable controls the pressure and is vital for the transmission to work?
can you guys help me out here thanks
Old Jul 13, 2011 | 09:16 PM
RSWORDS's Avatar
Here you go... And yes you need it.
https://www.dieselbombers.com/dodge-...djustment.html
oh and...
Old Jul 13, 2011 | 10:41 PM
blackout's Avatar
thanks you !...well apparently the kickdown doesnt work at all so thats why it was disconnected.. have any idea why it wouldnt work?
Old Jul 13, 2011 | 11:34 PM
jwirth's Avatar
surpised it wasn't burnt up being unhooked. is the transimission operating correctly. (all but kickdown) is it shifting right and does it have engine braking in low and 2 when you manually shift it.
Old Jul 13, 2011 | 11:36 PM
turbostang7's Avatar
Default Re: kickdown cable/ tv cable?
Is the cable bad? Should move freely inside of the plastic tube it goes through could have gone bad so they just unhooked it
Sent from my DROIDX
Old Jul 14, 2011 | 07:29 PM
blackout's Avatar
the cable is good. im going to hook it back on and adjust properly and see if it works . its been unhooked for a while now and is still drives good? thanks for the input guys. i will tell you tomorrow if i got it to work or not
Old Jul 14, 2011 | 07:42 PM
Begle1's Avatar
If you have a problem with it glued in the full-throttle position, then you are a more sensitive man than I am.
Old Jul 17, 2011 | 09:34 PM
blackout's Avatar
what do you mean begle?
Old Jul 17, 2011 | 10:06 PM
Begle1's Avatar
I have 300 HP, a Goerend converter and Suncoast transmission with manual valve body and ratchet shifter, and I can't notice any difference when I move the TV shaft one way or the other.
Old Jul 18, 2011 | 01:19 AM
jwirth's Avatar
