need advice for truck pull this weekend
Old Jul 13, 2011 | 09:28 PM
skyler1101's Avatar
Default need advice for truck pull this weekend
hey guys i need advice im going to a local truck pull this weekend and im gonna pull my truck in the diesel class im looking for advice im gonna start off in 3rd gear 4 low ill prob turn my fuel pressure up to like 23 so it wont get lower then 10 now my next question is once i hit 3k rpm will i have to back off and once my egt get to 1300 what do i do in this case anything helps thanks guys i got the 400hp 100foot pounds of torque south bend cluch also .. thanks guys!
anyone ha??
Last edited by skyler1101; Jul 13, 2011 at 09:28 PM. Reason: Automerged Doublepost
Old Jul 13, 2011 | 10:11 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
dont worry about egts on a short run like that. i prob get 1800 if i would look
Old Jul 14, 2011 | 06:36 PM
J-Pipes's Avatar
I'd say you're going with the right gear choice, and like pap said, a run down the sled track isn't long enough to worry about egts, once your clutch is up don't let the pedal up you aren't moving anymore!
Old Jul 14, 2011 | 09:34 PM
dukeboy_318's Avatar
I'd reccomend letting some air out of your front tires, maybe run 50% of normal pressures(i run my BFGs at 20psi when pulling) and maxing out the air pressure in your rear tires. Gives you a wider foot print up front and the rear tires aired up help with the load of the sled. Also, use a 4 inch clevis and a hitch pin thats heavy enough to handle at least 30k lbs or so as you dont want that to break while at max boost, measure your hitch height, I think my local rules are 29 inches from the ground to the clevis. Mine is set at 28.75.
If you start hopping bad, let off the go pedal and push clutch in at same time, avoid jamming on the brakes or the sled may hit your truck. Also, when you launch, slowly let the clutch out as you build boost but be fully off of it by the 25-50 ft mark or you could slip it or melt it together. Seen that happen before. Also, not sure what clutch you are using, but I hope its not a stocker or you're probably not going very far
Old Jul 15, 2011 | 12:01 AM
Red_Rattler's Avatar
High Tech Redneck
What gears and tire size? And the sled WILL hit you if you use the brakes
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
bubba_pa
Diesel Related Events
May 15, 2015 11:52 PM
twm011
Feb 24, 2015 09:11 AM
james2562
Nov 2, 2014 08:31 AM
