eating up powersteering pumps
Old Jul 13, 2011 | 10:23 AM
plumbob84's Avatar
Default eating up powersteering pumps
i have a 91 w250 and i am eating up the power steering pumps all i have dome is turbo and turned the pump up a little and straight pipe..does anyone know if i can run the hydrstatic system off a 94 12v to eliminate the vacum pump and the power steering pump problems i have and suggestions is appriciated
Old Jul 13, 2011 | 11:20 AM
t-bone117yamaha's Avatar
i would say put a double pump on it something more heavy duty is gunna help do you have bigger tires/ lift
Old Jul 13, 2011 | 11:24 AM
NadirPoint's Avatar
Originally Posted by plumbob84
...i am eating up the power steering pumps...
What's the failure mode? Leaking, overheating, grenading, what?
Old Jul 13, 2011 | 11:35 AM
plumbob84's Avatar
i have no lift and i run 285 65 16 at nothing aggressive. trucks a 5spd 4x4. my pumps 3rd one in 4 months are burning up getting so hot that it burns the fluid out of em
any suggestions are more then welcome i wanna upgrade or fix the problem im tired of changing them out all the time
Old Jul 13, 2011 | 12:16 PM
NadirPoint's Avatar
You probably need a new steering box - valve stuck or clogged. You could try flushing it. I run a cooler and filter in the power steering circuit on my 1st Gen - not because it overheats, but because the power steering systems on these trucks are minimal at best. Very little fluid in a system that has to contend with a D60 under a heavy front end.
Old Jul 13, 2011 | 02:55 PM
plumbob84's Avatar
what kinda kit is that or did you build it yourself for you cooler and filter
Old Jul 13, 2011 | 03:17 PM
NadirPoint's Avatar
Filter is a Magnefine - install in return line. Great little gadgets:
You get them lots of places. I think the last batch I bought came from Rock Auto. Just search for power steering filter.
The cooler is a Ford unit for an F-something I found on eBay for $10. You can see it in behind the bumper there:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_107.jpg
Plumb these in with a few bucks worth of tubing and clamps and you'll never have a power steering problem again - assuming the box is good.
Old Jul 14, 2011 | 12:15 AM
Chevy72's Avatar
Yes you can convert it and get rid of the vacuum brakes. I've seen a few people do the swap, seems pretty easy. search for it in archives, it's in there somewhere
How do you double pump?? I've never seen it before. maybe share some info??? I'm goona be running 35's when I get my Chevy done and i'd like to know more. Thanks
Old Jul 14, 2011 | 08:37 AM
plumbob84's Avatar
thanks for the filter info i will be pluming everything in this friday and that filter hopefully my box is good since it was just rebuilt 6 months ago ill let you know how it works out
Old Jul 19, 2011 | 09:56 AM
plumbob84's Avatar
well thanks for the info man it all went together like a dream flushed my box put a hardline from the pump to filter on the high side to the cooler to the box then new soft line on the return side with a filter should work out i hold about a quart more now and everything is staying nice and cool appriciate the help
JJ Diesel
Sep 14, 2015 02:38 AM
flogrownstroker
Mar 29, 2015 04:10 PM
Callmecowboy
18
Feb 3, 2015 09:01 PM
Callmecowboy
Jan 22, 2015 04:39 PM
