motor quits
Old Jul 12, 2011 | 08:53 PM
rf4-b's Avatar
Default motor quits
I just finished rebuilding my motor. It runs fine except when I let up quickly on the gas the motor stalls out. It starts back up fine and idles good. It has a rebuilt p7100 fuel pump on it. Is this the problem and if so can it be adjusted or could it be a timing problem. I timed it to factory specs. Thanks
Old Jul 12, 2011 | 10:05 PM
blazier18's Avatar
have you started with the basics? fuel filter could maybe play a little roll in that if its clogged up wat does the truck idle at rpm wise?
Old Jul 12, 2011 | 10:42 PM
daveO's Avatar
I had the same problem when my idle was set too low, especially when it was cold.
Old Jul 12, 2011 | 11:01 PM
12vcummins96's Avatar
it could also be a sticking dv
Old Jul 12, 2011 | 11:02 PM
Red_Rattler's Avatar
High Tech Redneck
How long have you had the truck running?
Old Jul 13, 2011 | 07:49 PM
blazier18's Avatar
i say its to low of idle on pump. thats just me.
