Engine Temperature Issue
Old Jul 11, 2011 | 03:22 PM
Sphinxj13's Avatar
Default Engine Temperature Issue
Im trying to figure out why my engine temperature rises when I have my truck in gear but im just sitting with my foot on the brake and not moving. Its fine when the truck is in park and when im driving but it rises about 20 degrees or more when im in drive and have my foot on the brake and not moving.
Old Jul 11, 2011 | 04:21 PM
NadirPoint's Avatar
Torque converter is probably the biggest heat producer in the whole drivetrain.
Old Dec 9, 2011 | 03:54 PM
12vChapa's Avatar
how, if it did not happen before.
Old Dec 9, 2011 | 06:06 PM
MurphyStrut's Avatar
Tranny fluid level??? If low could it cause excessive heat from TC? Just spit balling here
Old Dec 9, 2011 | 08:10 PM
tiremann9669's Avatar
Clogged tranny filter might be adding to the problem.
Old Dec 10, 2011 | 12:04 AM
Gerry R's Avatar
Default temp rise
With the trans in park there is no load on the engine but in drive there is a definate load hence a rise in temp. If you have an egt guage the egt will always be higher in drive than in park or neutral.
Old Dec 14, 2011 | 07:56 PM
12vChapa's Avatar
Nice good to know
Old Dec 14, 2011 | 08:08 PM
wildbill's Avatar
Coolant level, t-stat issue, faulty radiator cap could be 3 other factors as well.
burndiesel
10
Feb 7, 2023 01:15 AM
DBHX0311
Jun 19, 2015 11:57 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
