Do It Yourselfers! Tools needed to work on 6.0
Old Jul 10, 2011 | 09:33 PM
PowerstrokeTech87's Avatar
Default Do It Yourselfers! Tools needed to work on 6.0
I posted this in powerstroke.orgs forum figured id do it in here too.
RADKITPLUSA, Vacuum/Filler, Cooling System
This ensures no air bubbles, proper coolant level every time and no need to burp!
S6196KR, Socket, Ford ICP Sensor, 1 1/16", 3/8" square drive
This is the early build 6.0 Socket for ICP sensor. And no the turbo doesnt have to come out either to get to it same with IPR
OTC Tools & Equipment 6765 FORD 6.0L IPR SOCKET TOOL, StockWiseAuto
This is the IPR Socket. To pop IPRs out you dont need to pull the turbo but the engine has to be cold
SP60, Wrench, Fan, 1 7/8" (48 mm)
Fan clutch wrench
FTXEL40E2, Bit, TORX, Extra Long, T40
Youll need to do a little fabricating with this, youll need to shorten the bit and weld it to a socket 5/16ths
Ford 6.0L High Pressure Fuel Rail Adapters | OTC Tool Manufacturer for Cars and Trucks
This is what youll need for a suspected High pressure oil leak in order to air check it.
BLPTS1430, Socket Driver, TORX, Stubby, Blue-Point, T30
I use this with a 1/4 inch flex head ratchet to get the T 30 torx bolts out of the oil rail with
Mac Tools Online Store - MV7300
This is what i use to clean cylinders and oil/coolant galleries when doing head gaskets
The next 2 are what i use putting 6.4s and 6.0s together with
L872, Head, Sealed Ratchet, 5 15/16" L x 1 1/4" D x 2 1/2" W
L872RM, Handle, Knurled, Locking Button, 36"
Thats just doing head bolts, that bastard doesnt flex or bow
Fan clutch wrench
Last edited by PowerstrokeTech87; Jul 10, 2011 at 09:33 PM. Reason: Automerged Doublepost
Old Jul 10, 2011 | 09:36 PM
RAW's Avatar
RAW
Thanks for this, I'll be adding it to the Tech section.
Old Jul 10, 2011 | 09:47 PM
I got more like air ratchets impact guns hammer head air ratchets etc etc. Ive probably got just in tools-8k just to do 6.0 and 6.4s, another 6k in sockets ratchets screw drivers pry bars and 8200 for my Macsimizer.
My phone takes really crappy pictures...
Last edited by PowerstrokeTech87; Jul 10, 2011 at 09:47 PM. Reason: Automerged Doublepost
Cavnar
Sep 9, 2015 07:18 PM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Cavnar
6.0L Performance
Apr 7, 2015 10:35 PM
cjgregory
Mar 31, 2015 01:45 PM
scubasteve12
Mar 29, 2015 09:39 PM
