help dana 80 eating spider gears!!!!
Old Jul 9, 2011 | 12:58 PM
dieselpowertv89's Avatar
Default help dana 80 eating spider gears!!!!
i have a 2000 dodge 2500 with a dana 80 that keeps cracking spider gears. the cross is ok (well ok as in one piece) thrust washers mia. carrier appears ok. wondering about upgrades ???? and where to find them ???
Old Jul 9, 2011 | 04:07 PM
cummin_un_glued's Avatar
FormerVendor
is it the limited slip or open diff?
Old Jul 9, 2011 | 04:13 PM
Limited slip
Old Jul 9, 2011 | 11:04 PM
FormerVendor
you could replace the limited slip with a detroit locker that fits inside your carrier thats the only upgrade that i can think of....are you making alot of power or sled pulling or are they breaking with normal driving?
Old Jul 9, 2011 | 11:18 PM
First time it Broke I was pulling a friends bass boat, second time it seemed like it would lock up and not slip but looking at the clutch disc they were slipping. And once again pulling a bass boat. Some power 475hp never hooked up with a sled maybe want to in future. Now the detroit locker just replaces the spiders?
Old Jul 10, 2011 | 10:27 AM
FormerVendor
yeah they used to call it a EZ locker and it replaces the spiders and clutch's and cross pin, but i am not 100% sure that they make one for a D80
how do the packs look in yours? allmost sounds like maybe its lockup up on ya and causing them to break maybe
i've seen D80s fail but its usually sled pulling not just pulling a boat, makes me think there is possibly something wrong inside the diff
ok i done some more research for ya and detroit dosnt make the ez locker for the 80 but powertrax makes something similar
PT 2710 - PowerTrax $485.79 [13.20 Lbs]
Lock-Right locker for Dana 70 & 80 differential with 35 spline axles
Lock-Right locker for Dana 70 and 80 differential with 35 spline axles. This is a mechanically-operated unit which locks when power is applied, giving full power to both tires, and unlocks when you let off the gas. The Lock-Right unit installs into a standard open carrier, offering a lower cost alternative to full-carrier lockers. These units are not recommended for applications with high horsepower or large tires.
Relevant Tags: SPICER 80, SPICER 70, POWERTRAX, LOCKRIGHT, LOCKER, DIFFERENTIAL, DANA 80, DANA 70, LOCK RIGHT
Manufacturer Part #: 2710-LR
i got that from the randys ring and pinion website, i think i could get it for ya tho just pm me if your interested and i will do some looking monday
Last edited by cummin_un_glued; Jul 10, 2011 at 10:27 AM. Reason: Automerged Doublepost
Old Jul 10, 2011 | 12:01 PM
Blue01cummins's Avatar
i thought most of the dana 80s are posi units and they are rebuildable
Old Jul 10, 2011 | 01:07 PM
FormerVendor
most of the dodge units are posi units and yes they are rebuildable but he asked about an upgrade to the stock parts but yes i can also get all of the parts to rebuild it back stock as well
Old Jul 10, 2011 | 01:20 PM
i guess i dont understand what u mean by packs? but your most def right about it locking up and not unlocking. with this other locker you suggested am i going to have to drive differantly? (coast around corners) and it says big tires i am running 33s. a buddy told me to spool it
Old Jul 10, 2011 | 04:36 PM
FormerVendor
their are clutch disks that are inside the carrier we just replaced a set in a D70 this week because they were popping when the guy would turn sharp, the set for the D70 was around $80 for the clutch's only, in his the clutch material was gone and was causing it to grab so you could have the same problem.
yes the powertrax would be more aggressive then the stock diff
a spool would lock the 2 rear tires together all of the time which is great for competition only rigs but really dosnt work on the street, exessive tire wear, hard on axle shafts and so on
