D250 no power need help
Old Jul 8, 2011 | 07:21 PM
GFVD01's Avatar
Default D250 no power need help
OK i have a d250 automatic trans 2wd I can not pull anythig i put a 14ft enclosed trailer behind it and could not get overe 50 and 40 on the hills with no trailer i feel like I am driving my old peter built in 2nd gear I have ran the over head changed fuel filter staight exhaust cold air intake and still nothing any ideas being a diesel mechanic i am thinking it has something to do with the trany
Old Jul 8, 2011 | 11:58 PM
Marty Z's Avatar
What is the fuel pressure and boost pressure doing.
Old Jul 10, 2011 | 01:40 AM
mnwild_05's Avatar
how many miles are on the transmission?
Old Jul 23, 2011 | 11:11 PM
quickdart502's Avatar
I too have a 93 w250 with the same identical problem. I noticed in the beginning my fuel mileage dropped off considerably and found the torque converter was bad so I decided to by a new transmission from ATS. After I installed the new trans I got the fuel mileage back but the truck makes absolutely no power. I pull a 24' enclosed trailer and the truck pulls like a slug. At wide open throttle it will barely will run 55mph. Ive owned the truck since new and the truck is bone stock with 153,000 miles.
Old Jul 24, 2011 | 03:07 AM
jwirth's Avatar
Guess I shouldn't be upset with 90 mph with my 44ft enclosed on level ground .
Check and see if your torque convertor is bad. Do a Stall test if stall speed is high it indicates transmission slippage. if it is low on a properly tuned engine the torque convertor overrunning clutch has a problem stall with factory convertor is 1700-2000 rpm? that is out of my 92 factory service manual. hope it helps a little
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
