Hole in metal return line
Old Jul 8, 2011 | 02:09 PM
10fords's Avatar
Default Hole in metal return line
After doing a valve adjustment and replacing the gaskets it now appears I have a hole in the metal return line. It appears that you cannot replace just one section, or am I mistaken? Has anyone else had this problem and if so how did you repair it, and where did you get the parts? I guess rat **** is corrosive enough to rust a metal line! Is there any way to replace the metal lines with rubber like on my old Mercedes? Thanks for any help- Scott
Old Jul 8, 2011 | 05:17 PM
prison's Avatar
i'll start by saying i have no experience with with logic a return line would be low pressure so rubber should not be a problem at all
Old Jul 8, 2011 | 10:08 PM
10fords's Avatar
Well, I did a "temporary fix" by splicing in a piece of rubber line, but I need a new whole assembly. Anyone have a part # or know where I can get one? Or better yet has anyone ever ditched the metal line and found a banjo bolt with barbed fittings that will work?
Old Jul 8, 2011 | 11:35 PM
Marty Z's Avatar
Call Cummins
|WYG|SS
May 7, 2015 04:57 AM
|WYG|SS
Apr 28, 2015 03:59 PM
CumminsCoalRoller24/7
Apr 27, 2015 03:35 PM
Apr 21, 2015 09:03 PM
24vmaniac
Mar 4, 2015 12:37 AM
