Disableing MAP
Old Dec 28, 2007 | 07:12 PM
2500HeavyDuty's Avatar
Default Disableing MAP
Any way to Disable or provide false info from the MAP. I keep on getting engine over boost codes. I know of the ppe code eliminator also but if i spend that kind of money ill just get efi live
Old Dec 28, 2007 | 07:28 PM
LOGANSTANFORTH's Avatar
hmmm, get your voltage reading at the highest point before it kicks the light on and some how fool it with a resistor or something......
Old Dec 28, 2007 | 07:34 PM
ok, ill find some to go under my hood while im making 32 psi
Old Dec 28, 2007 | 07:39 PM
take the hood off or open it up and have someone ride on the front while you drive down the road.....
Old Dec 28, 2007 | 07:41 PM
well if i were to throw in a resistor and lets say it alters the voltage so it wouldn't throw the code to de-fuel it would instead add more fuel than its doing now then, right??
and then my only trouble will be adjusting the waste gate to hold more boost
ok lemme just go WOT to make full boost and by the time he/she gets a reading ill be doing 90mph
Last edited by 2500HeavyDuty; Dec 28, 2007 at 07:41 PM. Reason: Automerged Doublepost
Old Dec 28, 2007 | 07:47 PM
problem with a resistor is that it is the same no matter what, i think that will cause problems, i could be wrong though....
Old Dec 28, 2007 | 07:51 PM
i guess im gonna have to try and see what voltage i can get at idle, its hard to get these damn dmax turbos lit up with out a huge load
Old Dec 28, 2007 | 09:38 PM
Sea97Stroker's Avatar
You could do it with EFI Live.
Old Dec 28, 2007 | 09:43 PM
you can do your taxes with EFI live. But theres more other things i have to beef up before i get efi live, like my front end, and lift pump. and i got a 4.8k credit card bill to pay
Old Dec 28, 2007 | 09:44 PM
see thats why you shouldnt have a credit card.....
