no boost
Old Jul 7, 2011 | 11:41 AM
jigga747de's Avatar
Default no boost
ok here my problem, i got a new turbo ( a bd super b special) but mt boost gauge will only top out at about 20 psi. put a new gauge in and thats not it, no holes in the hose. only thing i can think of is the intercooler anyway i can check it or take it to a garage. any suggestions what else to check?
Old Jul 7, 2011 | 04:20 PM
wyodiesel92's Avatar
Do you have enough fuel to spool it? Wastegate adjusted?
If you need to pressure test you can make a setup with some pvc tubing caps and a valve stem.
Old Jul 7, 2011 | 04:34 PM
H.R.D's Avatar
Do you have a module that has a boost fooler on it or a stand alone boost fooler?
Old Jul 7, 2011 | 11:07 PM
Forgot that part too! Thanks h.r.d. if your not getting any boost fooling your engine will derate.
Old Jul 7, 2011 | 11:52 PM
H.R.D's Avatar
Here to help my friend.
Old Jul 7, 2011 | 11:53 PM
skyler1101's Avatar
If ur not getting any boost then those could be ur problems if ur getting some boost with high egts u prob blew out a gasket somewhere or have a leak or crack in a hose
Old Jul 8, 2011 | 02:36 AM
jigga747de's Avatar
im still running it stock with no programers, im getting the same amount of boost as i did with the stock turbo. what gaskets do i check?
Old Jul 8, 2011 | 10:07 AM
H.R.D's Avatar
Default Re: no boost
You need boost fooling or u will not see over stock boost numbers. Also need more fuel to get more air.
Sent from my DROIDX using Tapatalk
Old Jul 8, 2011 | 07:47 PM
Yessir, bigger turbo on a stock truck will yield harldy anything because of fueling and boost reading derating your fuel output. You could throw in 200s and still not see good results without boost fooling
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
