Oil pressure sender/switch install
Old Jul 6, 2011 | 08:17 PM
turbo20psi's Avatar
Default Oil pressure sender/switch install
I was driving down the road 3 weeks ago or so and my oil pressure gauge was all over the place. Everything got real tight . Noing that the oil pump in these cummins engine's are a beast,SENDING UNIT FAIL.The only oil pump fail I have seen was a marine engine with a fram filter on it..
Scanned for codes and produced a PO523=Oil Pressure Sensor High
Went to the cummins dealer and picked up a new oil pressure sender part#4921511.This part number is determined by the engine code plate that is on the side(Drivers Side) of the gear case. To take the old unit out I used a 1 1/4 inch socket to remove the sender (On the driver side under the cummins ECM). For the install the new sender was a 27mm deep.
I hope this helps out and here are some pics.
Attached Thumbnails Oil pressure sender/switch install-100_0643.jpg   Oil pressure sender/switch install-100_0644.jpg
Old Jul 6, 2011 | 08:34 PM
turbo20psi's Avatar
more pics
Attached Thumbnails Oil pressure sender/switch install-100_0647.jpg   Oil pressure sender/switch install-100_0644.jpg
Old Mar 16, 2012 | 12:59 AM
gregeureka's Avatar
Thanks turbo20psi I need to replace mine too and now I know where it is.
-=Greg=-
98.5 Dodge Cummins 3500 Duallie, Auto, remote trans cooler w/fan, 4" Turbo back SS Exhaust, BHAF, Superchips Tuner, more, with 3000 lbs. BigFoot 11' Camper in the bed.
Old Mar 16, 2012 | 09:04 AM
RAW's Avatar
RAW
Thanks for the write up! I'll be copying this into the Tech Threads.
Old Mar 16, 2012 | 11:40 AM
pukie370's Avatar
what did you pay. i went to dealer and they told me 360$ i fainted and wonder if there is other way to go.
Old Mar 16, 2012 | 12:01 PM
RAW's Avatar
RAW
Go directly to a Cummins Dealership, or any parts store should have them. The parts store may not carry a genuine Cummins part, but it will work.
Old Mar 16, 2012 | 02:57 PM
dieseldude848's Avatar
geno's are the cheapest, and there a genuine cummins part.
CUMMINS OIL PRESSURE SENSOR ('98.5-'02, 24V)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
