P-Pump questions
What's it take to do it. I have access to a 97 12 valve that's blown up and have a runnin 92 12 valve that I want to put the pump on
Sent from my DROIDX using Tapatalk
And i've heard about injector sleeves because the new 12 valves have smaller injectors and will the pump bolt right up?
IIRC you are going to need new sleeves for the injectors. If you do a search for P-pump conversion I'm sure you'll come up with a lot of good info. Kieron's write up is a good one, but his isn't the only one. There may even be something in the sticky about it.
There is a very good write up in the sticky, which is more step by step. It makes a pretty good guide, but its by no means 100%. The main thing is to get a second gen engine in front of you so you can visualize what the result will be. In my opinion it wasn't very hard once you get all the parts. and yes injectors have to get new bodies to accept the different size line nuts.
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
