holset pro 52 turbo fs/ft
Old Jul 5, 2011 | 09:10 PM
cummins-dodge's Avatar
Default holset pro 52 turbo fs/ft
looking to trade my holset pro 52 charger for some thing smaller like silver bullet or something around a 66mm
holset number 4027895
serial number 064813
98mm back face
71mm inducer
16cm non-w/g housing
01 dodge quad cab 5spd 285000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, industrial injection dragon fire pump, .093 connector tubes, .093 lines, ats head studs, 300 hp injectors 7x16 , s400 turbo and s300 twins, custom billet intake plate, cooling mist water meth injection, valair twin disc clutch 3850lb, 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
Pulling stats.
Hanks 4x4 3rd 282.56ft
01 dodge reg cab 5spd 282000 miles cold air intake afe, cooler tubz, single electric fan or I can put the stock clutch fan on, air dog 150 new 1 month old, stainless steal nerf bars, edge juice att. hot unlock, .093 connector tubes, valair single disc clutch, south bend hydrulics, 4inch from turbo to duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers truck for sale
96 dodge extra cab 5spd 172,000 miles cold air intake,191 delivery valves, 4-5k gov springs, holset pro 52 turbo, 60lb valve springs, haisley retainers, south bend dd 3850 clutch, south bend hydrolics, cal traction bars, 7 inch stacks, air bags,air dog 150, stage 4 ddp sticks, rear locker, mr bob’s hoses, american racing wheels, cooper st 285’s,
84 Chevy k30 reg cab with 94 12v p pump Cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, RQV gov., 370 injectors that are extrude honed bigger, o- ringed and head stud, milled off intake, sbc valve springs titanium keepers and retainers, portand polish head, marine lift pump, custom ground cam, cooling mist water meth. injection, valair twin disc clutch 3850lb, 1 3/8 input shaft, valair hydulic upgrade, industrial injection silver bullet 66 turbo, no fuel plate, .093 polish stainless steel fuel lines, aluminum radiator, single 5 inch miter cut stack
Pulling stats
Hanks 4x4 7th 256ft
03 Honda Rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted 170 main, spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 Yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 12.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod, full skid plates, heavy duty racing clutch, jetted
07 Kawasaki klx250 on off road bike moose air filter, fmf pipe mostly stock
Member stats
diesel bombers
the diesel garage
mopar1973man.com
Cummins forum
competition diesel
nyrok’s
atv connection
Old Jul 11, 2011 | 01:22 PM
billy-bob's Avatar
Default turbo
how much are you looking to get for it
Old Jul 12, 2011 | 06:59 PM
pm sent
Old Jul 14, 2011 | 11:42 AM
jmono33's Avatar
Why you going smaller? How did it spool?
Old Jul 17, 2011 | 03:39 PM
it is to big for daily driving and towing it spools around 1800-2000 rpm but once it lights hold on it spools hard it would be good for truck pulling or racing
Old Jul 17, 2011 | 11:15 PM
DIESELKILLER's Avatar
still for sale??? how much?
Old Jul 18, 2011 | 06:33 AM
still have it make a offer
Old Jul 18, 2011 | 04:06 PM
pm me how much you looking to get for it!!!
thanks
Doug
Old Jul 18, 2011 | 06:15 PM
pm sent
Old Jul 18, 2011 | 06:52 PM
Red_Rattler's Avatar
High Tech Redneck
A true pro 52? Upgraded shaft, pinned cover, pics?
