6.5 turbo on 6.2
Old Jul 5, 2011 | 11:14 AM
rollincoal69's Avatar
Default 6.5 turbo on 6.2
Ok i need serious answers here. will a 6.5 turbo work on my 92 6.2 the turbo is a wastegate turbo and i don't know if it will work HELP ME!!!!
Old Jul 5, 2011 | 04:47 PM
2MuchJunk's Avatar
Yes it will work. You will need to drill and tap a oil supply line in and pipe a return line in. The only real problem you might run into is the injectors are shorter in a 6.5 and it will cause the passenger side injectors to fit tight.
Old Jul 7, 2011 | 12:05 AM
whys that...i am not puttin 6.5 injectors in my 6.2 jus the turbo and intake and manifolds and all the bells and whistles that come wit the turbo system
Old Jul 7, 2011 | 12:21 AM
Woody35's Avatar
the newer 6.2s have the same injectors as the 6.5 im pretty sure
Old Jul 7, 2011 | 12:48 PM
What about the wastegate situation
Old Jul 7, 2011 | 07:12 PM
2MuchJunk's Avatar
If it has got a spring type waste gate your fine if it is vacuum operated you need to convert it to a spring type.
Old Jul 8, 2011 | 02:24 AM
well the guy told me it was a spring controlled turbo and i looked it up on heath diesel and its only like a 100 bucks for a aftermarket spring
Old Jul 8, 2011 | 09:29 AM
2MuchJunk's Avatar
If it is a spring type you don't need to buy a aftermarket spring to turn it up. Get a boost gauge. Then all you need to do is shorten the rod between the spring and the wastegate arm. You can do it by drilling another hole in the rod closer to the spring.
Hollie
6.2L & 6.5L Performance
Jan 14, 2016 01:32 PM
Brclouse
Nov 18, 2015 08:44 AM
Grey Rhino
Aug 12, 2015 06:47 AM
MIBoondocker
Jun 20, 2015 11:56 PM
Snoobly
Dec 11, 2014 11:59 AM
