HELP MAYBE STRANDED 48RE MORE PROBLEMS
Old Jul 2, 2011 | 03:49 PM
smokin daddy's Avatar
Default HELP MAYBE STRANDED 48RE MORE PROBLEMS
ok heres the story; transmission was shuddering 3rd into fourth. Did service, oil, filter, adjusted bands(rear was really loose). Only changed fluid in pan(ran out of daylight)filled with trans in neutral. Took it for a 10 mile drive, was awsome. Best since i bought it. Drove to work the next morning and problem returned. Drove back home and now have problems with 1st and 2nd bouncing back and forth, and same previous problem. Has 208k miles, had 180k when i bought it.
Old Jul 2, 2011 | 04:06 PM
dangerous1965's Avatar
Did you replace the soleniods? Also there is a gm style upgrade for the pressure regulator This is the best kit I've found! :DODGE HD TRANSMISSION SOLENOID PACKAGE 47RE 48RE 00 UP | eBay
Old Jul 2, 2011 | 04:13 PM
NadirPoint's Avatar
Default It's Time
My guess would be you got a truck with a trans that was already pooched by previous owner who ignored the service intervals and/or beat on it. They'll go longer than that, but 200k ain't that bad by any means.
Time for a rebuild?
Old Jul 2, 2011 | 04:22 PM
No i didnt change the solenoid. The main problem i'm having is there is so many oppinions on line that i dont know where to start. i have read so much on multiple sites that i've gotten confused about parts and brands. This is the first auto i've had and i cant afford right now to replace the trans. i just need something to get it going.
Your probably right Nadirpoint, i did notice when i changed the fluid it was brown, no burnt smell. The previous owner stated he "always" had the services done as scheduled.
I call BS.
Last edited by smokin daddy; Jul 2, 2011 at 04:22 PM. Reason: Automerged Doublepost
Old Jul 2, 2011 | 04:50 PM
Default Re: HELP MAYBE STRANDED 48RE MORE PROBLEMS
If the band has been loose then its probably toast.
Luke
Old Jul 2, 2011 | 05:52 PM
NadirPoint's Avatar
Default That's Normal
Originally Posted by smokin daddy
... i did notice when i changed the fluid it was brown, no burnt smell.
That's normal, but would also indicate it's got some miles and heat on it.
jeremiah1
Jul 21, 2015 06:35 PM
moroza
Mar 29, 2015 05:37 PM
Tucker126
Jan 2, 2015 08:09 AM
JRB1960
Dec 1, 2014 09:24 PM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
