turbo suggestions
Old Jul 1, 2011 | 11:31 PM
skyler1101's Avatar
Default turbo suggestions
Ok so everyone on here says for my amount of fuel get a turbo before i stack a smarty so here we go what turbo gimme suggestions i hear aurora is good???ny suggestions helpa
Old Jul 2, 2011 | 11:13 PM
dukeboy_318's Avatar
with your setup, a phfat shaft 62 or even a phaft shaft 64 would do wonders. but they are expensive. A s300 with a 62 or 64mm inducer will be good and a tad cheaper. Schieds, Industrial injection and HTT are very good normally. BD super B special turbos are pretty good too.
ATS auroa turbos are hit and miss, Personally, I've never ran one but I've got a few buddies who have ran them, some did good, others were complete junk so its pretty much a coin toss for me. Personally, I dont like ATS products, way over priced for what it is in my opinion.
Old Jul 3, 2011 | 04:40 PM
skyler1101's Avatar
nice nice ok ill have to check out these turbos im not going to be making so mkuch boost i blow a headgasket though will i cause i dont want that!
Old Jul 5, 2011 | 02:19 PM
skyler1101's Avatar
anything else to suggest ??
Old Jul 5, 2011 | 02:25 PM
Default Re: turbo suggestions
Good set if injectors and a 62mm or 64mm turbo will work great.
Luke
Old Jul 5, 2011 | 03:35 PM
1st_gen_puller's Avatar
head gasket failure is definately possible... i would highly recommend studs before a turbo upgrade..
Old Jul 5, 2011 | 05:48 PM
01quadcab's Avatar
save yourself time and money and stud the motor before you go any further and I don't recommend the smarty stack with edge you gain some bottom end but loose on the top end. for $500 or more for a smarty you can get a lot more out of something else. I would get a 62 turbo it will be good and you can always add a 471 or 475 under it for some compounds and make good power.
Old Jul 6, 2011 | 09:14 AM
skyler1101's Avatar
hmm i think u guys are right i will look into the studs
Old Jul 6, 2011 | 06:23 PM
we are.... ... been there done that... get the studs bud.....
Old Jul 8, 2011 | 09:26 AM
countryboy976's Avatar
How many psi of boost can the stock turbo handle and what would be the best turbo to upgrade to
