more timing...
Old Jul 1, 2011 | 05:48 PM
1st_gen_puller's Avatar
Default more timing...
how much timing is safe??? tweaked pump, non i/c, manual trans... thanks guys...
Old Jul 1, 2011 | 06:38 PM
Marty Z's Avatar
about 1/8'' is good. some go more
Old Jul 4, 2011 | 01:30 PM
thanks guy...
Old Jul 4, 2011 | 02:03 PM
KD93's Avatar
Depends on how much fuel you're trying to burn. Mine's set at 3/16" with no problems, but I've only got a turn or two on the full-fuel screw and small injectors. I could probably back it off a shade and it'd still be ok but it runs fine as it is, although a touch rattly.
I have yet to measure how much an 1/8" is, (standard 1st gen. timing bump) with regards actual degrees. But I know for certain that if you jump a tooth on your pump gear that will yield you a 10° advance. Some folks jump a tooth AND push the pump to the head. But, most of 'em are running big injectors.
Old Jul 5, 2011 | 09:29 AM
tower_ofpower's Avatar
If you have a little money to play with. The M&H timing spacer is ideal. Leave your timing stock and let the spacer alter the pumps dynamic timing instead. Only thing the 1/8th bump has over the timing spacer is that the bump is free
Old Jul 5, 2011 | 03:20 PM
money???? ha ha i charge the battery every 2 weeks cause i won't go buy an alt.. i buy 10-30% tread tires at farm sales for it... rattle canned bed.. i like free...
Old Jul 5, 2011 | 07:48 PM
Lmao, nice. Free is great. It's what's makes these trucks so much fun.
Old Jul 5, 2011 | 08:09 PM
ha ha... its the best... my buddy has a $20,000 d-max and he $h!t himself when i rowed the boat and waxed his @$$.... and i have 1/10th that $ in mine... i love VE's!!!!
Old Jul 12, 2011 | 09:52 PM
6btDakota's Avatar
I am making my own spacer for free. Its easy to make with patience.
Old Jul 13, 2011 | 10:11 AM
t-bone117yamaha's Avatar
what exactly is this spacer and how does it work? i had a guy telling me about them here in town but cant find any for sale?
